Enable SPB-PIM Gateway on a VLAN interface.
enable
configure terminal
interface vlan <1–4059>
If the IP interface does not exist on the VLAN. An IP Address must first be configured on the VLAN.
If the spbm_config_mode boot flag is set to false.
If the VLAN is configured with a circuitless IP.
If the interface is a management VLAN.
If ip igmp snooping is enabled.
If the spb-multicast is enabled on the VLAN.
If the VLAN has SMLT ports.
If the VLAN has an i-sid configured.
If the VLAN is a vIST VLAN.
